starts, runs for awhile and when it gets hot...shuts off
craftsman lawn tractor that will shut off after using for half hour or so. will restart after sittig for awhile.
Es esta una buena pregunta?
Not knowing exactly what model you have, I would guess that you are having a fuel issue. It is possible that you are getting a vapor lock. The fuel evaporates when the fuel lines get to hot. Make sure that you route them away from the engine block etc. Also reevaluate your ignition system, make sure that it does not get to hot. Take a look at your spark plug and see if it burns the fuel okay. Lsst thing I can think off is make sure that your gas cap is vented. There should be little holes in it, so that it will not create a vacuum. I believe that craftsman uses gas caps with washers underneath to vent the tank. Use an older one, it works better. Check all your fuel lines and delivery system to make sure they are not clogged, bend or otherwise damaged. Good luck
Fue útil esta respuesta?
i like the probable causes of what might be the problem. my name they call me JOHN BOY
It could be a resister ,I don’t think gas has anything to do with this problem
go buy this fuel filter and call me in the morning. lol part # 25-050-21-S it is a 75 micron filter not a 50 or universal.
I wish I could "call you in the morning" to thank you. I don't know if I ever would have thought of that...and I had already tried EVERYTHING else. Running great now... I really appreciate it!!
Thank you! I changed out the fuel filter to 75 micron and magic...ran like new!
Also, added Gumout to fuel cut my entire lawn without stalling once!!
Purchase a new carburetor for 30 bucks and be done with the problem, I did. Carburetors are cheap. Don’t rebuild, that will be 30 bucks if you do it yourself and you hope it works.
Replace ignition coil
I had changed the gas line, fuel filter, spark plug, gas cap and carburetor. Nothing made a difference. Replaced ignition module and problem was solved!
First check fuel cap venting
Then Valve clearance.
Runs OK when cold. When hot, valves open due to thermal expansion and insufficient clearance. This causes loss of compression until engine cools.
Regards
How do you clean the fuel cap vent hole?
Also, what valve are you talking about?
Thanks (newbie)
If there is negative pressure in the tank (when you remove the cap air rushes in) get a new fuel cap.
The valve clearance adjustment relates to the fuel inlet valves and exhaust valves. Usually one of each per cylinder, The correct setting will be shown in the engine specification document or workshop manual.
Typically 0.005" on small single cylinder engines.
I had more than one problem. There is a fuel filter that looks like part of a ball point pen that is pushed into the gas tank outlet nozzle. I pulled it out with needlenose pliers and cleaned it. It ran much longer but died when it was warmed . Next I adjusted the valve lash. After 3 pulls it ran like it was trying to die, then ran great and after about five minutes, died. I am going to adjust them again tommorow. If you have fuel and your mower dies when it is warmer up, you are probably looking at the valve issue you see above; hot valves don't close fully because of lack of clearance. There may be something else worse on my mower going on. If I fix it, I will post the solution.
It's not the valves it's a fuel issue clean the carburetor with an air compressor or gum out
Ultimas 24 horas: 27
Ultimos 7 días: 165
Ultimos 30 días: 554
Todo El Tiempo: 73,315
3 comentarios
I have a hustler raptor zero turn. Once it runs for a while & gets hot it shuts off. Not really trying to take it to the shop because I feel like it’s something so simple . Any have suggestions on what it could be?
- de PHAT TV
Hi I have a Morrison push mower when it gets hot it shuts down
- de robveevers326
Will the coil magneto being bad do the same thing
- de Roy McSpadden
