Saltar al contenido principal
El Apple Magic Mouse es un mouse multitáctil fabricado y vendido por Apple Inc. Fue anunciado y vendido por primera vez el 20 de octubre de 2009.
Preguntas 52 Ver todo
Can I replace the laser bulb?
Everything is working on my Magic Mouse but the laser sensor, itself. I can gesture, scroll, right click, double-click to select a word. BUT the laser no longer comes on, so I can't move the pointer. Can I replace the laser?
Es esta una buena pregunta?
Puntuación 8
1 comentario
can you explain me in detail that how you fixed it kaath9?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
I've never seen this part fail. I would suspect a failed solder joint. Of course if it is less than a year old, get a warranty replacement from Apple. If not, I'd tear it down and see if I could spot the problem. Here's the teardown: Desmontaje del Magic Mouse
Fue útil esta respuesta?
Puntuación 4
5 comentarios:
You're right mayer, mine wasn't working well, only clicks and movements but no cursor moving. Once opened, I've heater the laser pinouts with a soldering iron and it's working well now. The problem now is to fix the batteries plugs. In order to disassemble properly, we need to cut 2 plastic pieces who maintain the metallic rounded batteries plugs on the frame
- de
Can I solder without removing the capacitive sensor ribbon nor the battery case? @kospeia Did you achieve to do it?
- de
What Part of the mouse do you solder once you open it up?
- de
Asher Solder the place where you no longer have continuity.
- de
Thanks Mayer
- de
I had the same problem! After several attempts, I tried to push the lens with a pencil eraser, now it works fine
Puntuación 0
3 comentarios:
It makes me laugh, this is ifixit.
- de
Hello fabrizio,
Did you just press it up, without opening the mouse?
Thanks in advance!
- de
Hello Antonio, yes, you can do it without opening..... but ... the operation did not last much for me :-(
I think at this point that you have to open it and solder contacts with a soldering iron!
- de
Añadir tu respuesta
kaath9 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 28
Todo El Tiempo: 16,845
