A series of 15" media laptops manufactured by Dell.
Preguntas 23 Ver todo
Why laptop making beeping noise?
when i go to turn on my laptop the screen stays black while makin beepin noises it beeps 7-4times?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
3 Respuestas
Solución Elegida
You might want to check on HERE for the beep codes of your dell. I would remove the AC power, remove the Battery and also the RAM. Then try to reinstall it with only on memory module at a time. Also try one module in the different slots and see f it makes a difference. If your computer beeps 7 times, it is possible that it is actually a 3-3-1 beep which points toward the memory. Good Luck and let us know so we can all learn.
Fue útil esta respuesta?
Calificación 3
Depending on the beeps you should check the Memory or the Battery. Try connecting the power and then remove the battery so it boots if you still get the beeps you might have change your memory.
Calificación 1
just clean memory and try 4 times if dosent work maybe you need to replace your ram.
Calificación 0
Añadir tu respuesta
bernettafolmar estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 12
Últimos 7 Días: 53
Últimos 30 Días: 153
Todo El Tiempo: 22,228
