Saltar al contenido principal
Aquí puedes consultar guías de reparación para MacBook.
Preguntas 3786 Ver todo
Screen Discoloration, color distortion, help deciding what to replace
I want to know if I need to replace the whole LCD or if I can replace an Inverter or a different display component or possibly do some cleaning. I have some photos of the broken mac next to a fully functional mac as well as some pics of the back side of the screen. I know that I probably need to replace the LCD but I am trying to stay cheap. This mac is a MacBook 2,1 2.16 GHz
It is definitely not a display setting, I have tried all of those and the screen is distorted even at the initial boot up.
Es esta una buena pregunta?
Puntuación 4
3 comentarios
What does it do if you hook it up to an external monitor?
- de
How Do I Fix my MacBook Air with Discolor to the Screen? I can't see my FaceTime. Help?
- de
Hi, I seem to have the same discoluration problem on my macbook MacBook (Retina, 12-inch, Early 2016). I'm not good with tech and taking things apart. my macbook is only maybe 3 years old and in brilliant condition. Never spilled anything on it ever and look after it pretty well. What can I do or who can I take it to? Im in Florianopolis BRazil at the moment.... thank you!
- de
Agregar un comentario
2 Respuestas
Solución Elegida
There's corrosion on your LCD electronic board, on the LVDS connector/socket and also signs of electric shorts (black spots). I guess liquid was spilled in this area. You can begin by cleaning the corrosion with isopropyl alcohol and a small brush but IMHO the LCD will have to be replaced. Let us know if the cleaning job was enough to restore a normal video. Good luck.
Fue útil esta respuesta?
Puntuación 5
3 comentarios:
Thank you for the great idea. I used a little rubbing alcohol on some q-tips to clean the dirty spots and the display is as good as new. I saved $100 instead of buying a new LCD.
- de
Hey, that's good news Shawn. It seems that the black spots were not signs of electric shorts and only the corrosion altered the video signal. Great !! Thanks for accepting my answer (-:
- de
+ Nice answer lemerise - Those black spots are/were shorts. _______________+ Shawn GREAT presentation of your problem. I wish everyone posting their problem here would put that kind of effort into it.
- de
This could be caused by a few different problems, that you should try ruling out. First, try connecting it to an external monitor. If it works normally, then you have a problem with the LCD panel/LVDS cable. If it still displays abnormally, then you have a logic board problem. (More specifically, a problem with the integrated graphics chip) The only way to repair this is to reflow the GPU, or replace the logic board all together.
Puntuación 0
Añadir tu respuesta
Shawn estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 20
Todo El Tiempo: 19,390
