Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
Preguntas 1960 Ver todo
Replaced battery-camera not working now
Followed IFIXIT directions. everything works fine except the camera. The screen opens but the lens ( on the screen) does not open and the icon of the camera and the movie "flicker" I have taken the phone apart again down to the battery and reassembled everything..........same thing no camera....:-(
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
You may have just damaged your camera ribbon. Take things apart again, and make sure you snap the camera into the connector securely, THEN install the camera+board together into the housing. If that doesnt work, then try replacing the camera. When it is apart, inspect for any tears or kinks in the camera ribbon, it doesnt take much to render it damaged.
Fue útil esta respuesta?
Calificación 1
This blog post fixed it for me, it's just that the connector to the camera isn't quite in correctly: http://hamiltonnicholas.blogspot.com/201...
Calificación 1
Añadir tu respuesta
nils estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 6,293
