Complete disassembly and installation guides for most recent Mac laptops and consumer desktops.
Preguntas 31365 Ver todo
Apple Hardware Test Failure Code: Help
Hello Everyone,
I was just playing around with my macbook 4,1 and decided to do Apple Hardware Test. Which resulted in
failure code: 4SNS/1/40000001: VG0C-0.070
I did some research and seem to indicate a sensor failure on the logic board. Though I have not had any no problems with this laptop for the last 8months(2nd owner) I was wondering if anyone could shed some more light on this error code and if I should be concerned
Thanks
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Comentarios:
good job. Thanks for sharing.
por
Agregar un comentario
5 Respuestas
Solución Elegida
Apple doesn't tell the peons what those codes mean. But if you would like to spend about $47.50 they will tell you. Just call 1-800-SOS-APPLE. But my opinion is, "if it ain't broke, don't fix it".
Fue útil esta respuesta?
Calificación 5
You could try running Techtool Pro from Micromat.
I used to be Mac Certified - and I couldn't get error code info ?? !
Calificación 1
Run the extended version of the Apple Hardware Test. Sometimes you will get an error if you run the quick version, and it may be something of a false positive. Some have found doing an SMC reset 3 or 4X can eliminate the error (note: a work around not a fix). If it is indeed a logic board error it points to a sensor(s) failing, VPOR might be VGC(VPU) related. You'll probably need a new logic board, AFAIK sensors as well as the VGC are soldered to the logic board which pretty much makes them non-DIY repairs, as soldering on logic boards are not for amateurs.
Calificación 0
Thanks for sharing this helpful article.
Lyrics Song: https://bodakyellowlyrics.com
Calificación 0
Failed while i checking my Lotto game result on my apple laptop. Please tell me how to solve that issue.
Calificación 0
Añadir tu respuesta
Jamie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 22
Últimos 30 Días: 60
Todo El Tiempo: 1,724
