Why dose my car keep overheating?
I have a 1999-2005 Pontiac Grand Am gt 3.4
let me tell u what i have done so far.
replaced:
water pump twice
thermostat twice
temp censer twice
intake gaskets / manifold gaskets
vale cover gasket
system been flushed countless times
resevoir and cap replaced
and still over heating radiator being replaced now! i know on these cars there was a problem with the dex coolant system and was a class action suit that ended in 08 and dose not help my only had it for 6months. but cant find what t do fix the problem. please help
Es esta una buena pregunta?
14 comentarios
It's most likely the catalytic converter clogging 60 bucks cheap fix. I diagnosed my car at AutoZone for the check engine and that's what it was and it has fixed my overheating issue, also it you have a bad engine leak diagnose it before paying for an intake manifold gasket, right above and to the right of the oil filter on a 3.4 v6 grand am there's a oil pressure sensor and you have to buy a certain socket for it as well but if it is bad it will be pouring oil out like a small fountain so change it, ten dollar fix over a thirty dollar fix.
- de Harley Lambert
Email me plz to fix my car problem .i hsve the same problrm after she cools off she ststts up again i changed two sensors landrade6635.la@gmail.com
- de Lucy Andrade
I have the same issue but i change thermostat twice i change my temp sensor once and my engine
Light not on but it's making a loud knocking
Sounds sometimes. Please help
- de Leveda Boyd
Fans on my 1999 Grand Am four-cylinder car will not come on car is overheating help please
- de Shauna
Hi my name is Rodney i have 04 grand am 3.4 go to pfyc.com they have a capers hi speed fan switch its about $100 it's comes with built in relays u can turn ur fans on manually and it won't interfere with ur control module takes about 30ins to install
- de Rodney Walster
Mostrar 9 comentarios más
