Can not come on but the red light is come On
how to fix a samsung plasma tv PS51D450A2XZN that can not come on but the red light is come On Pls help me
Es esta una buena pregunta?
commonly if the standby indicator illuminates but you are unable to turn on the TV, it is a main board issue. It would help if you give us more information about this. Information about since when your TV is doing this, has anything happened to it and what you have tried to repair it. You also want to go ahead and remove the back of your TV and check the boards and interconnect cables for obvious damage etc. Post some images of your boards with your question. That way we can see what you see. Use this guide Agregar imágenes a una pregunta existente for that. Also, see if your TV has a chassis number on the label. That will help a bit more than just the model number.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 67
