How to replace blower fan
where and how do you replace a heater-A/C blower fan.
Es esta una buena pregunta?
Alan,
1.) Check the fuse
2.) See if you can test the voltage to the blower motor. If you have voltage, you have a bad motor.
3.) Check the blower motor resistor if there is not voltage to the motor.
Either way, check out this PDF on location and diagram for replacement of both parts.
Regards,
Frank
Fue útil esta respuesta?
Can you send me full manual link
This is a recall issue. Bad wiring causing resistor to burn out. Recal #15402
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 9,865
