Vizio m50 - e1 screen replacement
Hi
I need a screen for vizio m50 - e1 50”
Es esta una buena pregunta?
Hi
'''++Ayser Asim++''' you can try and contact Vizio and see if they can help you. Most manufacturers will not help you with that. Vizio is a different beast altogether. They use whatever panel they can get their hands on for their TV’s. So in order to look for a panel, you will have to remove the back from your TV and check the label on the panel. It should have the maker and the model number of the panel on it. Then do a online search and see if you can find a panel that matches. Keep in mind that replacement panels, if they are available, are often more expensive than a new TV
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 171
