Saltar al contenido principal
Aquí puedes consultar guías de reparación para MacBook.
Preguntas 3786 Ver todo
Screen is covered with lines with large black spots and border
My mac screen is almost completely covered with vertical lines white screen and black spots with black borders. It started off with vertical lines, few days later a large black spot showed up then I noticed the top of the screen was turning black almost like it was leaking black ink. If I take a screen shot the ugly screen doesn't show up in the image. On top of that my computer will not work unless its plugged in. What do I do?
Es esta una buena pregunta?
Puntuación 2
3 comentarios
I was away from my chrome book for a few minutes. And when I came back my screen was covered in lines and big black lines. It looks like the computer is cracked. But when I turn it off and feel it, there is nothing. My chrome book won't even charge. I'm not sure what to do.
- de
My sisters is just like that and i have no idea what to do either please tell mme if you figured it out
- de
I dropped my laptop and now the ink is rising and there are lines on it what do I do
- de
Agregar un comentario
3 Respuestas
Solución Elegida
I am 95% certain you need to replace the LCD based on your description. However lets do a few things to rule out all possibility of it being any thing else. Move the upper part of the laptop that holds the lcd backwards and forwards from the hinge, while observing the display. If things get better or worse by doing that it could be the video data cable or a bad connection to that cable. Hook up an external monitor up if the picture is good on an external monitor. Then it is either the LCD or the video data cable. If the picture is similar on the external monitor the it is most likely either failing video memory or GPU. Please let us know more after you have tried these test and we will help you get the part that needs replaced and provide a guide to replace it.
Fue útil esta respuesta?
Puntuación 7
2 comentarios:
+ sounds good to me:-)
- de
I just replace the LCD and I'm getting the same vertical gray lines! I can move one line left to right with my finger on the pad.
- de
Sounds like you need to replace your LCD. Go under the Apple icon in the upper left hand corner to "about this Mac", more info, >Hardware > Graphics/Displays. Get the information on your screen.
Also please give the last three letters of your serial number so we know exactly which machine you have. (located in the battery compartment). This will allow directing toward the correct guide.
Puntuación 2
What about this!
Puntuación 0
Añadir tu respuesta
Erinn estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 33
Todo El Tiempo: 37,030
