Saltar al contenido principal
Los Razer Blade Stealth son una línea de Ultrabooks premium de Razer. El último modelo es el Razer Blade Stealth (2019)
Preguntas 48 Ver todo
Laptop screen wont turn on but keyboard and razor logo will light up
Is there a way that I can get my laptop screen to work again? The keyboard back lights work and the razor logo on the back of the display works when I turn it on. But I get nothing from the display itself.
Es esta una buena pregunta?
Puntuación 0
2 comentarios
I am also able to connect a HDMI cable to it and I can get the laptop to display on an external display.
- de
The touch screen works. This confuses me.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @birdup
What is the actual model of your laptop?
If you flash your torchlight on the panel, can you see anything on it?
Some issues that could be causing this, e.g. like Faulty LCD module / panel, Faulty LVDS Cable, etc
Fue útil esta respuesta?
Puntuación 3
1 comentario:
@birdup "the razor logo on the back of the display works" means you have a working backlight. The digitizer is separate from your LCD and right now it appears as if you either do not get a signal to the LCD or the LCD screen is just not working. Since the external display works I would go with a new screen
- de
Añadir tu respuesta
Harrison Reisinger estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 41
Todo El Tiempo: 7,128
