Battery not recognized after sata cable replacement
I have a Mid 2012 MacBook Pro in which I recently had to replace the sata cable. I was getting a blank white screen and no hard drive was showing to boot to. I had a colleague of mine, who previously worked at Geek Squad with Best Buy, replace the sata cable for me. When I gave him the laptop, the battery worked fine, the only issue was the hard drive was not showing. After he replaced the cable, the computer booted up fine and everything in regards to the hard drive was working. However, the battery was not showing as active or available.
There is a {X} symbol on the battery when logged in (top right corner) as if it is not connected.
Things I've tried:
- Known good charger (same result)
- New battery (same result)
- SMC reset (I performed the keyboard command but I'm not sure how to tell if it was successful or not)
- The battery indicator on the left side of the laptop does not light up at all
I would like to add that about 2 years ago I did have water spill which affected the firewire port (which I never used), but it still worked after that with no issues for 2 years.
Any help would be greatly appreciated.
Es esta una buena pregunta?
