Saltar al contenido principal
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 2375 Ver todo
Screen damage pressure? White spot
My iPhone 4 has a white spot in the middle of the screen, well is a spot wich is whiter, this can only be seen if you have a white backgroud, so when you have dark colors on the back you dont noticed. I got worried about this and i pressed harder the spot and the screen went kinda purple on that very spot, so im guessing is a damge for the pressure this spot, please help me, dont know what to do, thanks
Es esta una buena pregunta?
Puntuación 4
1 comentario
My phone Alcatel PIXI 4 has a white spot everywhere on the screen. Please help me to solve this kind of problem. Thank you
- de
Agregar un comentario
4 Respuestas
Solución Elegida
It sounds like there is a slight dip or imperfection on the back side of the digitizer. It is collecting more light from the backlight. If it is under warranty take it in for repair. They may exchange it so I would back up your information on it. Digitizers are not made to have above gentle touch pressure. The touch screen is glued directly to the LCD I would imagine you would get a kind of purple color pressing firmly on it, since that is the native color of an inactive LCD. If it is not under warranty and not interfering with reasonable normal use I would live with it. If you can't do that you will have to replace the screen assembly. The instructions for replacing your screen are here. New screen assemblies are here.
Imagen de iPhone 4 (GSM/AT&T) Screen
Producto
$24.99
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Look at this video. Screen replacement is expensive solution before that you should try some tricks like these. https://www.youtube.com/watch?v=PxUOlqaN...
- de
I also have a problem like this. There is a yellow/green/purple spot on my display.
iPhone 3GS, iOS 6.1.6
Also, try not to press on it. You may make it worse...
Puntuación 0
1 comentario:
It may be something up with the digitizer, as ABCellars said.
- de
The only solution for this is screen replacement? no other way?
Puntuación 0
3 comentarios:
you may have a case that is too tight. the bright white spot happened to me and as soon as i took the case off (after reading this) it went away
- de
Thanks ,taking off the case worked !!1
- de
did it went out right away?
- de
Once try refixing the Digitizers (display) and while fixing do not over tight the screws
Puntuación 0
Añadir tu respuesta
Rafael estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 29
Todo El Tiempo: 150,295
