Lines inside bottom half of television
My tv has some lines on the bottom of it, how much would it cost to fix it?
Model is KDL-40XBR4
Es esta una buena pregunta?
Model is KDL-40XBR4
@mazino that will depend on what causes those lines. You are not giving us enough information to help you a whole lot. This sounds like a panel error and would be expensive since it is next to impossible to replace the LCD, but unless we can see if it will only be a guess. Post some images of what your screen displays with your question. Use this guide for that Agregar imágenes a una pregunta existente Also, and this is very important. What is the exact model of your TV.
Fue útil esta respuesta?
i have posted it
@mazino looks like a bad LCD panel. Sorry there is no repair for it. You will need to try to find a replacement for it. A new panel, if even available, will most likely cost more than your TV. Try to find a TV that uses the same panel but is broken other places and harvest the panel from there.
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 689
