Saltar al contenido principal
La actualización de marzo de 2015 de la pantalla Retina MacBook Pro de 13" de Apple, modelo A1502, presenta procesadores Intel Core i5 e i7 de quinta generación e introduce el trackpad Force Touch.
Preguntas 1185 Ver todo
Black screen but works fine with external screen
Hello,
I have a MacBook pro 13" with retina display, kinda new. my screen stopped working suddenly and doesn't display anything. It boots up and displays perfectly through an HDMI on external screen. I am also able to adjust my screen brightness!
not sure which part is broken.
I'd appreciate any advice.
Thanks a lot,
Shany
Es esta una buena pregunta?
Puntuación 2
1 comentario
I have exactly the same problem on my Macbook Pro Early 2015 ed. Mine will start working perfectly when I connect it to external monitor either through HDMI or Thunderbolt but when disconnected it will either go blank or start flickering. Any help pls
- de
Agregar un comentario
6 Respuestas
Solución Elegida
Shine a flashlight into the Apple Logo in the display are you able to see the faint image of your desktop and its icons? If you can only your backlight logic needs to be looked at.
Update (04/21/2018)
At this point, I think you'll need to pop the bottom cover off and inspect the display cable connection. Review the this IFIXIT guide: Reemplazo del conjunto de la pantalla del MacBook Pro 13" Retina Display de principios de 2015. After disconnecting the battery jump down to Step11. Take some detailed pictures and post them here for us to see.
Agregar imágenes a una pregunta existente
Imagen de iFixit
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Imagen de MacBook Pro 13" Retina Display Early 2015 Conjunto de la pantalla
Guía
Dificultad:
Moderado
30 minutes - 1 hour
Fue útil esta respuesta?
Puntuación 2
9 comentarios:
I did but can't see icon images.
- de
What do you see?
- de
By flashing a light into the apple logo in the display, I can't see anything just black screen. increasing the brightness works and the apple logo is on but there is nothing on the screen.
- de
Not understanding what altering the brightness does here as if the screen is black and it stays black that doesn't tell us anything as far as the internal display.
- de
I can't see anything on screen but altering the brightness makes the black screen lighter :-) just thought that might help to narrow down the root cause.
- de
Mostrar 4 comentarios más
[EDIT: Update, had to reopen to reseat keyboard backlight connector, so again unplugged and replugged display connector - now when I shine a light through apple logo I can see the screen displayed, just no backlight.]
I am having a similar, but not exactly the same, problem: I get no backlighting (apple logo does not light up), and shining a light through it does not show anything.
One night I had an external hooked up via HDMI, watching a movie or something, turned my brightness all of the way down, and the next day my screen would not come on, but works perfectly with external. Brightness controls work, just nothing happens with the screen. A couple drops of rain may have gotten on it, not soaked just a couple/few drops - nothing else was affected (eg isight works).
I have opened the case and unplugged, inspected (seeing nothing of note) the cable, replugged, and closed the case. Have not tried using any electrical contact cleaner yet, but will do so later.
[Edit: Adding pic September 18, 2019… this pic isn’t very good, but it shows the connector in the monitor I mentioned in my later comment.]
Narrowed down the problem to the display inverter:
Does anyone know where to get these?
Puntuación 2
2 comentarios:
Forgot the electrical contact cleaner! It won't help here.
Sounds like you have a blown fuse. But before we dig into this lets check the display connector and the cable. Turn off the system again and disconnect the display connector and take a good close up of the pins on the cable end and the solder joints of the socket and post them here Adding images to an existing answer
- de
Two things to add here:
1) While it had been just the backlight that was not working, today I noticed the actual display is not working, including the backlight control (previously the backlight was not working, but the control did).
2) Also today, I removed the monitor and discovered that the connector looks like it might have burnt a little, same connector as pictured in pictured in Han Ming Saw's comment on Black Screen - External monitor works
Oh, and thank you for your reply, Dan. I don't get any notifications for replies on this site, nor do I see any place for that option, so I'll need to remember to come back to check (just saw that there was a comment when reading another, similar page).
- de
Hi there,
I am no computer expert but it would seem that based on your previous answers, that there is something wrong with the LCD seeing as the backlight works but there is no display. The 2 solutions I could think of are:
1. Connect an external display and do a safe boot( Power + Shift) It probably won't help but it is best to try anyway.
2. If you are willing open it up and see if there is a loose connection or inspect for any damage to the LCD
Try them and report back
Puntuación 0
1 comentario:
Abraham, you're on the right track! If you reread what shany wrote "It boots up and displays perfectly through an HDMI on external screen" we've gone past that.
- de
Im having the exact problem but with my iMac, any ideas?
Puntuación 0
Thank you All
Already did the Step 11 on the guide. Disconnecting and reconnecting it but it does not work… Any extra help? My screen keep being black, although it works well with HDMI.
Puntuación 0
2 comentarios:
I am having the same proble. did yo get any resolution? Thanks, Ann
- de
You need to turn on the computer and log in after you have unplugged it. Then turn it off, plug it back in, and turn it on again.
- de
Hey i have a macbook air and my screen is black. Ive connected a monitet but it is extended the first screen so the black screen is still there.
Any tips on how i can just mirror the screen?
Puntuación 0
Añadir tu respuesta
shany estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 19
Ultimos 30 días: 112
Todo El Tiempo: 31,398
