Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Preguntas 394 Ver todo
iMac won't turn on
Hello.
I inherited an iMac (27-in mid-2011) this year. The previous owner had removed all their files and reinstalled all the latest iOS etc.
We were able to get it started after I picked it up over a month ago. I had left it on and plugged in for a couple of weeks and then last weekend I realized it had gone 100% dark. It has been like that ever since. Have tried different outlets. Tried plugging and unplugging back of machine. Tried removing accessories (just keyboard). I replaced the old power cord with brand new one, but still no life.
I'm a newbie in DIY repairs but I guess I'd like opinions on whether to return to Apple Store for scrap, or if it is worth troubleshooting via some IFIXIT solution (and if so what would you try first?). Thanks for any input!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Solución Elegida
If you can carefully remove the display iMac Intel 27" EMC 2429 Display Replacement you should be able to see the onboard diagnostic LED's Which are just below and to the right of the HD on the main logic board
Do any of the LED's light up? If not and your sure the power cord is good and plugged into a good outlet then the power supply needs replacing. Here's the guide you'll ned to follow to take it out: iMac Intel 27" EMC 2429 Power Supply Replacement and here's the needed part: iMac Intel 27" (EMC No. 2309, 2374, 2390 or 2429) Power Supply.
The tricky part is not damaging the display cables when you take the display off.
Imagen iMac Intel 27" (EMC No. 2309, 2374, 2390 or 2429) Power Supply
Producto
$149.99
Imagen iMac Intel 27" EMC 2429 Display
Guía
Dificultad:
Moderar
15 minutes
Imagen iMac Intel 27" EMC 2429 Power Supply
Guía
Dificultad:
Moderar
20 - 30 minutes
Fue útil esta respuesta?
Calificación 3
Comentarios:
Nice! - Thanks, Dan & Eigirdas! I will take a look at that guide + replacement! If I do replace the power, and it powers on again - Assuming hypothetically it is then in decent running order, how many years do you think potentially it may have left in it? Is that something anyone can estimate? One or two years at least? Or are there other components that typically die?
por
Mine is still kicking ;-} And I'm hoping to get at least 3 more years if not more! I've upgrade it with 16 GB or RAM & a second drive (500 GB SSD) it really sings!
por
That's awesome!! I'll let you know how it goes. Thanks again!
por
Just to clarify.... when you pressing power button, it makes no noise, sounds ?
Calificación 0
Comentarios:
Hi! Yes, that is correct - there is no sound. No indication of life. I have been on the phone twice with Apple Support, to attempt to turn it on. They no longer support this machine so will not be able to even try to repair. They were going to set up an appt for me to drop it off but I thought I would see if there was any ifixit option before I do that.
por
Follow Dan then, because hes comment was identical to mine:D
por
Añadir tu respuesta
Amy C estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 29
Todo El Tiempo: 82
