Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
Preguntas 1394 Ver todo
Why does my battery drain fast even after replacing the battery?
My iPhone 6S has been draining very fast the past few months so I decided to buy a battery off of eBay (good seller, good ratings) and replace it. There were no hiccups in the repair process, no cables were damaged. When I plugged it in and charged it to 100% today, it still drained very fast with minimal usage. I don’t pull my phone out at school at all and I started the day out with 100%. After 7 hours my phone was down to 3%. Keep in mind I don’t pull my phone out a lot in school. In the battery tab of my settings, the apps look normal with my social media apps taking ~25%. However, when I see the time stamps, there are only about 30 minutes of use on them(active and background). I installed Battery Life Doctor on my phone to monitor the battery health and it says the new battery is fully healthy at 1715 mAh. On the estimate for how much time I have left until my battery runs out, it says a little less than 10 hours, but my battery decays very fast. It will jump from 7:30 remaining to 7:10 remaining in a matter of a few seconds. How do I troubleshoot this?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Solución Elegida
It's possible that you're replacement battery is not very good. However, with a good reading from the battery app, you're problem may be elsewhere. I'd be curious to see what the app says about your original battery. Also, you could use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows). It will also tell you what the health of the battery is and may be interesting to get a second opinion.
Otherwise, you may have a modular component that is draining the battery. Does the phone feel abnormally warm/hot? You could try to disconnect modules (cameras, sensors etc.) one at a time and then test the performance of the battery.
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
Jonny Xu estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 73
Últimos 30 Días: 250
Todo El Tiempo: 474
