A smartphone released by Xiaomi in January of 2015. Features a 5.7-inch display and 13MP camera.
Preguntas 17 Ver todo
XIAOMI MI6 newest smartphone with no backlight after water damage
I accidentally drop my Mi6 into a pool of water and the phone just went completely dead nothing happen when I tried to power it on. I dried it and it power on but no backlight :( I wonder can my phone still can fix from water damage or not, if yes what should I do? How much it will probably cost for repair from the damage in the workshop?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Does the image on the display works properly?
por
Yes, it works properly, the problem is backlight.
por
Agregar un comentario
2 Respuestas
Respuesta Más Útil
I've found a tutorial here on ifixit
How to fix liquid water damages in Xiaomi Mi 6 Phone
Fue útil esta respuesta?
Calificación 2
Hello Artur,
Water damage repairs can range from several minutes to several days depending on the level of corrosion on the motherboard, the number of unsalvageable parts that need to be replaced. Generally, professional water damage repair can cost between 10% to 60% of your devices' brand new value.
I would recommend finding a local shop that has experience with microsoldering. The type of shop that only handles iPhone screen replacement and little more will rarely know what to do to repair damaged circuits. Generally they just scrub the motherboard with alcohol and a toothbrush and hope for the best. That's not to say there's anything wrong cleaning the board to start. It's just that after the first aid kit fails, your next step should be an emergency room with real doctors, if you get what I mean.
Calificación 0
Comentarios:
Why this repair is so costly? You've mention that it could be the 60% of the phone value, I think it is pretty expensive.
por
You must disassemble the phone completely, clean it properly and it is also necessary to change parts like battery or screen. The time is gold
por
Añadir tu respuesta
Artur Milek estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 15
Últimos 30 Días: 31
Todo El Tiempo: 105
