4-inch iPhone released in March 2016 with similar hardware specifications to the 6s. Available in Silver, Space Grey, Gold, or Rose Gold with 16/64 GB storage options. Model A1662 and A1723.
Preguntas 333 Ver todo
Always has "Could Not Activate iPhone" error
As stated above, it's getting this error every time you try activating it, either via local or iTunes activation. Various software resets etc have all been tried. CDMA based unit. Some techs suggested the SIM slot could be damaged. I'm looking for advice what the actual issue is called in the repair world, and if anybody knows a good tech to help with it locally in South Bay Area / San Jose, CA, or via mail order since it's somewhat more involved than a typical phone repair would be.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Do you try to restore it via 3tools software?
por
Is it an iTunes error or something different?
por
How do you resolve the matter with this error?
por
Agregar un comentario
4 Respuestas
Respuesta Más Útil
Maybe this will be a little help for you:
How to fix iTunes error -1 in an iPhone SE
Fue útil esta respuesta?
Calificación 5
Use 3UTools and check if the IMEI is being displayed on there. If it is not then the issue is related to the baseband circuit area which can only be fixed by microsoldering.
iPad Rehab should be able to help you out, not sure where they are located in.
Calificación 3
SOLVED!
I had the same problem just let your phone completely die until it gets to 0% and then charge your phone and then wait for it to turn on and it should be at your normal lock screen again and it should be working fine.
Calificación 1
Comentarios:
Should I wait until it turn itsel off or plug the charger just before?
por
Text copy replacement and email are waaaay tooooo smiiiiiiiiiiiiiilllllllllleee
Calificación 0
Añadir tu respuesta
Matthew Hall estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 26
Últimos 30 Días: 127
Todo El Tiempo: 230
