Saltar al contenido principal
Modelo A1320 / 8 o 16 GB de capacidad
Preguntas 155 Ver todo
Did I just ruin this iPod?
I was trying to remove the battery from the logicboard, and two little brown pads came off of the board , did I just ruin this ipod?? It's my sons and he's going to be heartbroken. I can't afford to get another one please help me fix this someone.
Update (03/12/2018)
Attached are pictures of the solder connections on both the battery ribbon and board
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
if the two little brown pads that came off are fabric-like then you should be fine, if it is anything else i'm not sure
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
The pads were the point on the board that the battery ribbon was soldered to
- de
Can you add a picture? if its the pads that came off, you may (with a little bit of soldering experience), be able to run a jumper to the pulled pad from the trace its connected to.
- de
if theres any solder left on the board you can use carefully rebuild the connection...if not youll need to find an alternate solution to charge...you can get a new logic board and battery for under $20 online .
Puntuación 0
Añadir tu respuesta
plantdad estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 114
