BRAKE light on dashboard
Hi everyone,
I need help knowing what I need to fix since my BRAKE light on my dashboard is on after I fixed the brake hose on the drivers side and replaced both front and back brake pads.
Thank you.
Es esta una buena pregunta?
5 comentarios
Have you checked the handbrake?
- de S W
Have you checked your fluid level, as that is what the brake light usually represents in older cars.
- de sm_vulkus
Hey guys,
Sorry for the long reply but it turns out I fixed it by accidentally pressing the brakes too hard and then the BRAKE light in the dashboard shut off. Now whenever I start my car the light turns off.
Thank you guys for the help. I'll keep your answers as future references jist in case. Thanks again.
- de vladsc50
I have a 1996 Toyota T100
My dash brake light was on, constantly, since I replaced my front disk brakes completely - all new parts!
I fixed the problem by remembering a stupid fix I had read about a few years ago!
The fix?
Believe it or not... it was due to my brake's master cylinder reservoir being filled up to the MAX line! REALLY?!
So I drew out the brake fluid from the reservoir until it was half way between the MAX line and the MIN fill line. Problem solved!
- de gfry
The brake light will also come on and remain on if your emergency brake cable is stretch out. If you readjust it or install new emergency brake cable then the light will go off.
- de industrialfarmhousemarket
