Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1687 / A1634. La Reparación de este dispositivo es similar a las generaciones anteriores, requiriendo destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16, 64 o 128 GB / Silver, Gold, Space Grey o Rose Gold.
Preguntas 1041 Ver todo
Where is this rubber thing supposed to go?
While I was replacing the iPhone 6s Plus Lightning and Headphone cable a little rubber thing showed up as I removed the Headphone assembly from the phone. I figured out that it came from the headphone jack, but I don’t know where to put it back.
Does anybody know?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
I don't know what it is, but I can tell you it is a waterproofing gasket of some sort.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
its supposed to thread down on the new AUX port.
Its not 100% necessary to have, but thats where its going to be.
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
Where exactly is it supposed to go on the AUX port? Which way?
- de
It should match up with the iPhone housing headphone port hole, you can experiment which way it sits against the housing.
- de
That is the gasket that fits over the end of the headphone jack. To put that back on you will have to go through the procedure to replace the lightning connector assembly which includes on it the headphone jack and two microphones.
Puntuación 0
Añadir tu respuesta
Daniel Kendel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 11
Todo El Tiempo: 102
