What is the unusual sound of MacBook Pro?like a type sound
what is the unusual sound of mac book pro?like a type sound
Es esta una buena pregunta?
it sounds like its your hard drive
Fue útil esta respuesta?
A retina model don't have a hard drive (uses SSD)
Most likely your cooling fan has something stuck in it so its unbalanced hitting the frame of the fan enclosure.
Get a small soft paint brush and a can of can'ed air as well as the needed tools to open your system. You'll also likely need thermal paste and cleaner if you take the fan fully out. I would try first to just scrub what you can get to with the paint brush and then use a few short soft blasts of can'ed air to blow away the debris (Stop at Step7)
Here's the IFIXIT guide you'll need to follow: Reemplazo del ventilador del MacBook Pro 13" Retina Display Early 2015
First check in the applications > utilities > activity monitor. Whether there are any large programs memory/leaking filling up the CPU. Making your machine run hot. It could be worth de-installing / upgrading any problematic software.
Then second, reset the System Management Controller (SMC)
https://support.apple.com/en-gb/HT201295
It could be picking up dust on the internal fan. You can take the rear cover & give it a dusting with a BONE DRY small paint brush
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 132
2 comentarios
I’m not sure exactly what you mean? Can you give us more info on the problem please?
- de Padraic Hoselton
i'm not sure but sound like a tik tik tik!
- de saba
