The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
Preguntas 3505 Ver todo
iPhone 5s won't turn on
Hi! I have an iPhone 5s fallen in water. He was in bootloop so I tested the battery and it was dead. I changed the battery and the bootloop continued. So I remove the EMI shield and there aren't water damage but now the phone won't turn on. Initially it warming around the Power IC and all the capacitors around it were short-circuited. I heated up the Power IC and now the capacitors are ok but the phone won't turn on. I leaved in the battery all night long and it has fallen from 3.80V to 3.16V. Please, can you help me?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
I had a similar issue with an SE, got wet, wouldn't accept a charge, was bootlooping... new fully charged battery didn't fix it - replaced the charging port board and everything worked after that. If you don't have another 5s to swap parts with, I suggest trying a new charging port board.
Fue útil esta respuesta?
Calificación 0
Añadir tu respuesta
Eliseo Di Iorio estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 36
Últimos 30 Días: 135
Todo El Tiempo: 298
