Samsung's flagship phone, the Galaxy S8. Released in April 2017.
Preguntas 57 Ver todo
My phone stops charging around 90%
I have changed the battery out of my Galaxy S8 but a problem has started to show that it doesn't want to charge pass 90%. I'm thinking of the USB c port board but I don't have a clue.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
If your phone is out of warranty try replace the micro usb board.
por
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Did you try to replace the batter? Sometimes the easiest solutiona are the most effective:
Samsung Galaxy S8 Plus Battery Replacement
Fue útil esta respuesta?
Calificación 4
Is the phone rooted or running a custom rom or kernel?
The models that come with a locked bootloader have this issue where they only charge 80% max with root / custom.
Calificación 1
Comentarios:
No mine is an unlocked phone, what I'm going to try and do is let the battery die and charge it back up and see if it'll fix the problem, if not I suppose it's a software issue.
por
Well now that the phone has died the phone does not want to charge while it's off.
por
Well I think it's more so the battery going faulty rather than the type C port but who knows until either get replaced.
por
I changed the battery because it was faulty, but it did it on my battery that I got from fixez too.
por
Did you buy original battery or a cheap replacement?
por
Añadir tu respuesta
Darrell Ross estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 15
Últimos 30 Días: 56
Todo El Tiempo: 144
