Saltar al contenido principal
El mando (controlador) inalámbrico Xbox One 1697 se lanzó en 2015 y reemplazó al controlador 1537 y soluciona algunos de los problemas encontrados en los controladores modelo 1537. El controlador modelo 1697 incluye un conector para auriculares integrado de 3,5 mm, que permite la compatibilidad con la mayoría de los auriculares de terceros sin adaptador. Este controlador ha sido descontinuado y reemplazado por el controlador Modelo 1708.
Preguntas 75 Ver todo
Does anyone make a MicroUSB cable that works well with this controller
I've had this controller for 15 months and for the time I have owned it, I've never used the wireless because the Model 1697 controller only supports IR and USB connectivity. Because I don't own the wireless receiver and these controllers get terrible alkaline battery life, I've always used mine over MicroUSB to avoid having to buy batteries on a regular basis.
While this method works, I've been having a hard time finding a good MicroUSB cable that works well with this controller and doesn't wear out quickly.
The problem with these controllers is the connection is smaller then other MicroUSB connections. I have posted a picture of the connector in the controller for reference: (The Model 1697 controller is a minor refresh from the 1537, and the connector is the same)
Are there any good cable options I should look for that work well with this controller, or is it more or less impossible to find a good one that's 3rd party? The official cable from the Play and Charge kit doesn't work without the battery and doesn't work as a wired cable on the PC. It blocks 5V with the battery or 3.3V without the battery. The PCB in the cable is designed so it only works on the Xbox One console with the battery installed.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
How about soldering in a braided wire? https://www.amazon.com/dp/B012A1221Q/ref... just chop the micro USB connector off the end of this one.
Update (02/01/2018)
Actually, Here's a braided one for xbox 1 controllers. why braided? from my experience it extends the life of my apple cables soooo... https://www.walmart.com/ip/Microsoft-Xbo...
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
@nick not sure or not if you get a notification for updates, so here's this.
- de
I'm not sure if Microsoft does the same thing they do with the Elite cable as they do with the Play and Charge cable. I doubt it, but I've never seen anyone with one yet to verify that.
- de
The ones on monoprice.com are really good and come with a lifetime warranty.
Puntuación 1
Añadir tu respuesta
Nick estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 2,504
