Saltar al contenido principal
La única versión wi-fi del iPad Air de Apple, número de modelo A1474. Disponible en Space Gray o Silver, incluye el procesador A7 personalizado y se envía en configuraciones de 16, 32, 64 y 128 GB.
Preguntas 299 Ver todo
Screen goes extremely dim
My screen is almost always extremely dark (no icons visible just very dim light) sometimes it helps to hit it on the back a few times for a few minutes but then it goes flickering/ green to black again. I also tried reset and completely reinstalling it without luck. I guess the LCD cable is loose? How much would a repair cost?
Edit: sounds like a backlight problem according to a local repair shop, he said repair costs 120€... is it possible to fix it by myself, without technical super skills?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Depends. It could be the LCD going out (which is a DIY) or a backlight coil, which would need micro soldering.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Thanks for your answer! "LCD going out" means I have to buy a new LCD screen for109$ ?
I wonder if I could fix it somehow with a harder hit on the side as the screen works perfectly sometimes...
- de
You should have a warranty from your supplier.
- de
It is better to fix it hitting it just rigs it to work for a while just replace it alway the way to go. And how about having the lcd tested on another I pad this will help diagnose what the issue is!
If you have any questions or concerns please comment below. Thank you
Puntuación 1
Añadir tu respuesta
Bastian estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 11
Todo El Tiempo: 311
