Saltar al contenido principal
Modelo A1136 / disco duro de 30, 60 u 80 GB / frente de plástico negro o blanco
Preguntas 797 Ver todo
Can I fix a severed hold switch ribbon?
When replacing the battery on my iPod the battery was so stuck with the adhesive, that when it finally came loose, I severed the orange ribbon cable that goes to the hold switch. As such the iPod thinks it's eternally on hold. Can I fix it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
The ribbon cables are so small and delicate that repairing the ribbon itself isn't really an option. However, replacing the headphone jack/hold switch assembly (30 GB or 60/80 GB) is an inexpensive and easy repair. (If you successfully replaced the battery, this will be easy as well for you).
Good luck!
Fue útil esta respuesta?
Puntuación 2
1 comentario:
replacing the hold switch/headphone jack would be your best bet!
- de
You could snip the cable to add a finer cut, but this would not let the ipod go into hold, just turn on, and stay on
Puntuación 1
Añadir tu respuesta
gary estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 4,292
