Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
Preguntas 3220 Ver todo
battery percentage drops rapidly
battery percentage drops rapidly when using like i use it for 10 mins and it drops to 30 % from 70% and some times it shuts itself down at 40% or %)% and sometimes 8% .
sometimes when you restart it the battery percent drops hugely like 80% to 13% .
im in desperate need of help
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Needs a new battery.
Reemplazo de la batería del iPhone 5
The kit is $25:
iPhone 5 Replacement Battery
Imagen iPhone 5 Replacement Battery
Producto
$24.99
Fue útil esta respuesta?
Calificación 3
Comentarios:
you sure nothing else works ?
por
A software update may fix it.
por
Well this is the usual procedure for diagnosing battery drain:
1. Backup phone via iTunes, restore via iTunes, restore from backup.
2. If issue still persists proceed with battery replacment
3. Still no good? Probably Tristar Charging IC needing to be replaced via microsoldering.
por
Añadir tu respuesta
vamsi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 3
Todo El Tiempo: 52
