brake system problem, abs light comes on
my abs light continually blinks or stays on and says check brake system, all wheel drive also blinking.
Es esta una buena pregunta?
Many things could cause what you are describing. Without scanning your car's computer for what is going on it would be hit and miss diagnosing the cause(s). A number of people are not aware of this but many auto parts stores, including AutoZone, offer free diagnostic hook-ups. I would call around to find an auto parts store that does the free diagnostic scan on your car's computer. This is not a direct solution to your problem. It is the most economical and feasible one I can think of.
The computer diagnostic scanners that the auto parts store will hook up for free is the same one(s) used by many mechanics who will charge you for the service.
Fue útil esta respuesta?
Good information here. If the diagnostic indicates a problem with the ABS I would agree with oldturkey and take it to a pro. +
I know exactly what this is, it is called the ABS Tone ring, replaced 2 myself, not overly complicated, yet not overly simply. It is common in these Escapes mine is 2005. My abs and 4x4 light came on, and sure enough it was the tone ring, happened to the other side 6 months later. Look behind the tire for something that looks like an exposed gear, with teeth connected to the axel, it is likely broken. there is one on all 4 tires, in my experience the fronts are more likely to fail. I got them at 1aauto.com. Luckily i sprung for the 2 pack since it was only a little bit more. Turns out my logic/intuition was correct, if one failed the other probably will, 6 months later bam! good luck.
my mechanic told me about these sensors behind the wheels and that my front passenger wheel was not lined up correctly. He said good stable monitoring of wheel rotation requires this sensor to be in the correct position and it sometimes requires repositioning. So he repositioned it & also put a small weld to secure it. He said sometimess these sensors have a hard time reading the data from wheel rotation accurately, which is required for ABS systems to function properly
Anyway, I am not sure what part you are referring to in your scenario but was curious if this is the same. It's located on the axle, from the explanation I got. I would like to see a blow up schematic showing all relevant parts that pertain to ABS. It seems like an affordable piece that's very installable for someone who does basic repairs. Any ABS light issues I've encountered in my lifetime are usually wheel sensors, unless a major brake system failure occurs at which time I replce calipers, rotors and pads as well as the brake line assembly to the wheels. (referring to front end on 2004 Escape)
YOU MY NEW FRIEND KNOW YOUR FORD ESCAPE MY 2009 FORD ESCAPE. THIS HAPPENED CAN YOU NASER MY QUESTION?i just got gas ok. next morning im oing down a hill/ EVERY THING FAILED. THE CAR WOULD NOT STOP HEAR ME I HAD TO PUT FOOT ON RAKE PUT INNEUTRAL.IT WOULD COM TO COMPLETE STOP FOR 10 SECONS AND JUST GO FORWARD NO WAY TO STOP IT I JUST HAD TO BRAND NEW TIRES OIL CHANGE OIL FILTER IM NO DUM FEMALE COOLANT I USED WAS 9 YRS OLD I NO I SHOULD NOT HAV USED THAT I HAVE BAD SENSORS MY TIRE SENSOR THEN OIL SENSOR CAME ON RIGHT AFTER OIL CHANGE. WHAT WLD HAVE CAUSED THE ESCAPE TO EVERYTHING WENT BRAKES I WOULD EVENTUALLYEND IN THE RIVER SMH
According to my mechanic, the sensor failure caused the ABS and 4WD lights to come on. The sensor was damaged by the drive shaft to the wheel. Once the sensor is damaged the pressure applied by the brake system is inconsistent. In one day both my front rotors were warped. I had to replace two rotors, brake pads, sensors and get another part on the drive shaft that did not cause the sensor to break.
After hearing all this, I looked into Ford Escape brake problems. Seems like they can go out at any time and come back on without a cause???? Many people are writing about near acciddents, accidents and Ford's refusal to do anything about this very dangerous brake issue.
What was the problem? My 2007 is doing the same thing and they are guessing it's my ABS pump which is $1,500 to fix! It only tore up my front drivers side rotor and break shoe but again like you said will continue to do that.
andi,
this may be as simple as debris in the reluctor rings on any of the wheels.in winter or inclemant weather it is a common problem. since the warnings recieved have this signal in common you would be well advised to check these before spending diagnostic $$$$..
I agree as with some above and from my experience having a 2005 escape, that its one of your wheel speed sensor "tone" rings! the issue for me was the exact same warnings "service four wheel drive" alternate with "service brake system" I had it looked at and fixed by an ex ford mechanic workmate whom is now a millwright and has a shop at home and does mechanics on the side, and sure enough the ring on right passenger side was split causing it to move away slightly from its normal position, he told me that apparently these rings are made extremely thin and over time rust forms underneath from moisture, expands and finally splits the ring! in my simple layman's understanding its the wheel speed sensors that determine which wheels are spinning at which rate, if for example both front wheels stopped rotating and back ones still turning then vehicle realizes its in a skid and the abs is activated. same with the auto four wheel drive if various wheel slippage is detected then that system is engaged! my neighbor has the same vehicle and experienced the same warning problem within a couple of months of mine! the replacement part was surprisingly inexpensive with this new found knowledge of what his problem was I was able to help him replace his in his carport with the aide of a Haynes manual as a guide and of course a little more time taken than it would of a more experienced mechanic! :)
Absolutely spot on! This is the best explanation I've seen. Tone rings and sensors are the first things you should check when an ABS light or message comes up. Rings break, sensor wires get broken, sensors go bad. Bravo.
The Reluctor Ring, or commonly called a "tone" ring, is a magnetic feedback device that usually surrounds a vehicle's axle or cv joint in the vicinity of the brake at each wheel. It is easily identified as a ring with notches cut into it, commonly about a half inch wide or slightly less, and 4.5-6" in diameter, depending on the size of the axle or cv joint in the vehicle. The "nodes" in the ring (spaces between the notches, pass by the magnet in the wheel speed sensor(s) that sits at a specific distance from the ring, creating an electrical impulse that is sent to the ABS controller, or Brake Control Module (BCM).
The ring and sensor count the nodes as they pass and calculate the wheel speed at the brake of each wheel. The vehicle speed sensor, in turn, should correspond with the reading at the wheel. The only time these values are NOT equal is when a wheel is locked up and sliding under hard braking conditions. In this condition, the BCM recognizes the values as inequal, and it engages the servo at the ABS unit, which allows the pressure in the brake lines to repeatedly "pulse" as the pressure is released.
Reluctor rings, like anything else, can go bad, often due to rust between the ring and the axle, causing the ring to split and to dislodge from its calibrated position and setting off the ABS light. Sometimes the ring can lodge against the spindle, steering knuckle, or hub assembly, either shattering the parts around it or even causing the wheel to lock up entirely. Adverse brake performance can also result.
Brake systems are THE SINGLE MOST important system in a vehicle, do NOT touch them unless you are trained or experienced, your life literally depends on it!
Tone rings are not always replaceable alone, as they're often part of the axle or cv assembly, so costs can vary widely. Replacing axles or CV joints often requires forces exceeding several hundred pounds and can be incredibly dangerous to perform.
Hope this information helps, and be safe.
That is correct for the 2012 and earlier. The 2013 and beyond have a magnet pressed into the wheel bearings in the front. If that magnet is cracked or damaged will cause this problem. If the sensors are replaced and the problem still exists start checking the magnets in the wheel bearings for damage.
May want to google "tine gear" common issue with this truck. I own one and had this issue
had the same problem.. mechanic told me that the axel was broken and after changing that he will check the sensors.... can that cause the abs light on??
I just recently replaced my two front rotors and brake pads on my 03 Ranger XLT.
After completing the job I drove it around the block for a test drive.
Half way around the block, I had a real stiff pedal, then all of a sudden I started hearing a popping sound coming from the engine compartment, that sounded like bee bees hitting an old tin can.
Half way through the stop the pedal went soft.
I continued driving around the block and after a dozen stops, the ABS light came on.
So...Back in the driveway where it has been sitting until I figure this out.
Air in the system. Did you open any bleeder screws or loosen any lines to back the calipers off? It's a common mistake. Bleed the front brakes until no air bubbles come out. Check your brake lines and hoses real close. Sounds like you might have a brake hose swelling and contracting. They shouldn't do that. Rusty metal lines can split also.
Did you lube the caliper pins before putting them back in? If not this will cause the break pads to stick and the anti-lock kicks in.
I have to drive it the Auto Parts Store Like Auto Zone and I'm worried about driving it right now . I was to be in at work but I couldn't because of how its driving.
The 2012 ford escape titanium has tone rings for the ABS. 2013 and beyond don't have tone rings but instead have a magnet pressed into the wheel bearing. If that magnet cracks or is damaged the ABS wheel speed sensor can't read the wheel speed properly. Unfortunately if the magnet is damaged the only way to fix it is to replace the wheel bearing if its the front ones. If its the rear ones then you can get the hub with the bearing already installed.
Ultimas 24 horas: 5
Ultimos 7 días: 48
Ultimos 30 días: 163
Todo El Tiempo: 221,743
16 comentarios
This is one of those issues where I would definitely take it to a qualified mechanic. Not something I would try to attempt to fix myself.
- de oldturkey03
2004 chevy venture the brake peddle pulsates when applying on the brakes to hard the abs light comes on then releasing your foot off the peddle it goes off?
- de mark
200i escape. Just got in dec. Already had work on transmission and exhaust. Now the traction light and abs lights are on doesnt seem to drive much different but just started last night. Being a female im afraid to drive it and on low income dont know what to do..
- de Judie
Have had same problem with 2009 f150 for the last 8 years. Truck was one yr old when started; have had it into shop many times [6-7] they reset the computer and it goes away for a while. Light always come back and code always says lost communication. Got tired of paying for programing and didn't want to start parting out so I took a look at abs control unit and noticed the wire harness plug was lose, you could move it up and down easily. I took a .10 wire tie, zip tie, put it around plug and abs unit pulled tight, problem solved. Its been over 2 months and no lights on dash, I believe the plug was loose and whenever I hit a pothole or just vibration, it came lose. I can't believe the amount of money and time was spent on a loose plug.
- de gary d
Check the fluid and make sure that it's not leaking brake fluid on The opposite side of your back tires. These was the reason my light repeatedly kept coming on.
- de hdfge4t35t34g
Mostrar 11 comentarios más
