Saltar al contenido principal
La aspiradora vertical Dyson Cinetic Big Ball Animal (DC75 Animal) es para varios pisos y es fácil de utilizar. El número de modelo es 206031-01. (UP14)
Preguntas 10 Ver todo
Hose is getting sucked in and crimped at suction base
I have a ball animal 2 vacuum. The hose is getting sucked in and crimped at the base. I checked for blockages and did not find any. It's also not sucking up as much as it should. Any suggestions? Thanks in advance.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @kristieleigh19 ,
Have you checked that the filter is not clogged up?
Fue útil esta respuesta?
Puntuación 1
5 comentarios:
I will remove and wash them and see if that works. Thanks!
- de
Have you pulled the hose off and make sure you can see light all the way through? Typically if your hose is collapsing, there is a blockage issue somewhere.
- de
Yes and nothing is there.
- de
Does the sound of the motor and suction change when you disconnect the hose from down by the ball?
- de
Yes, sound changes. Plz help
- de
Añadir tu respuesta
Kristie Dilxger estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 1,680
