Saltar al contenido principal
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
Preguntas 104 Ver todo
Front and Rear Windshield Washers Not Working
The windshield washer fluid will not come out in neither the front or the rear. I checked the fuses and they are both fine. Any thoughts on what it could be? I watched a video on replacing the pumps and they mention there is a pump for each window so I'm not sure how likely it is for both pumps to go out at the same time. Thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario:
Same problem here. Were you able to find a solution?
- de
Agregar un comentario
1 Respuesta
I had to change both. There on the left side by the front wheel. I went to Ford to replace them.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Lucia Munoz estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 15
Todo El Tiempo: 1,728
