Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2688 Ver todo
iPhone 6S Components on PADS Layout Viewer
Hi
I´m have been looking for the possible reason why my iPhone 6S is not charging, I have read some topics about the possible problems that could cause it to not charge, some of them talk about the Tristar IC, but not only they as well talk about some other places that I should check as well in order to have a full diagnostic, of the voltage going through the phone. I don’t have the full understanding of the board circuits, so I have checked for an application that could give that to me. I will post two prints of that, but one for iPhone 6 and the other for the iPhone 6S.
I have been looking for those names, but I could not found anything that assure me that those names were correct. But for the iPhone 6 I have seen lots of confirmations about the showed names on the print.
Are the components started by the “X” on iPhone 6S correctly, or the displayed information is incorrect on PADS Layout Viewer?
Thanks.
Es esta una buena pregunta?
Puntuación 6
Agregar un comentario
1 Respuesta
Solución Elegida
The designations on the PADS boardview (starting with X's) do not correspond with the schematic diagram so that will make troubleshooting very difficult. Your best bet is to find the schematic...it is available in the wild (sorry, can't share it here).
Here is a snapshot from the schematic that corresponds to your view:
Using the schematic will allow to follow the circuit and see where those components are located. As an aside, Tristar is a good bet for charging issues but it could also be Tigris/PMIC.
Fue útil esta respuesta?
Puntuación 6
Añadir tu respuesta
Henry Adams estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 4,157
