Saltar al contenido principal
The Lenovo ThinkPad X1 Carbon 2nd Gen is the second generation of Lenovo's X1 series ultrabook.
Preguntas 8 Ver todo
No backlight with blown fuse under lvds connector
Good day
i have thinkpad x1 gen2 with black screen, i can see faint image with torch and external display works fine, i disassemble it and saw a blown fuse under lvds connector on main-board, i replaced it with same fuse and it blown right away after single test, there is an 8pin IC next to the fuse which i believe to be for black-light or something which is not good i think, i want to replace it but i can not read its number so i can order it, will someone help me identify this IC,
https://ibb.co/bGjPe6
https://ibb.co/mz0msR
Thanks
Es esta una buena pregunta?
Puntuación 1
1 comentario
I found Fuse 1 blown replaced it .
the Fuse is on the opposite side of the motherboard where the screen connector to motherboard is , it is covered in sticky protective plastic.
unfortunately to me the laptop stopped powering on something else has happened to it that I could not fined yet.
Power starts green light flashes then the fan starts then power off follows
- de
Agregar un comentario
1 Respuesta
Solución Elegida
On my X1 carbon gen3 it says F:2B on that IC.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thanks alot Jarlvik, Yes it is F:2B but just cannot find it anywhere on internet. Greets
- de
Añadir tu respuesta
Khizar Hayat estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 2,882
