Why is my 5 speed 1993 xlt stuck in gear
Why is my f-150 5 speed xlt
hung in gear
Es esta una buena pregunta?
hung in gear
Johnny Johnson you definitely can remove the shifter with the transmission remaining. Actually you will have to remove the shifter to drop the tranny. Here are the instructions from 1980-199 Ford Pick-Ups. Typical Haynes, kind of crummy but hope it'll help you out.
Since yours is a 5-speed and you did not mention anything about OD, I added the manual for the Mazda S5-42 ZF Transmission Mazda_Ford-ZF-S5-42-Transmissi.pdf
Fue útil esta respuesta?
Thank you very much I will try this , I will need this.
Johnny Johnson you are welcome. BTW great truck and those are real workhorses. Keep it going....
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 3,929
2 comentarios
1993 f150 stuck in gear
- de Johnny Johnson
Clutch is ok, slave cyl. was leaking down got that fixed, 165000 mi. think my nephew crammed it in gear while cyl. was weak. I am feeling like the shifter has jumped track or broke. I think I can take shifter up from floor to see. My question is can I fix it that way or do I have to take trans. out of the truck. Thanks for responding.
- de Johnny Johnson
