Saltar al contenido principal
Presentado en el 1290 New York International Auto Show en 2004, el Xterra fue rediseñado para 2005 en la plataforma Nissan F-Alpha utilizada por Frontier, ingresando a las salas de exhibición en abril de 2004 para el año modelo 2005.
Preguntas 6 Ver todo
No Acceleratror pedal control
I got a code p2122, accelerator control sensor on my 2005 Nissan x trail. I have changed the pedal control sensor and the fuel control on the intake and checked the connectivity of all 6 wires from the pedal to the control body and all seems to be fine. I still have engine light on with code p2122 and no response to the pedal still. Where should i go searching now?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
1 comentario:
I now have this problem also. I have replaced the throttle body and the pedal sensor and still the gas pedal does not work. Have you finaly solved the problem and what was the repair if so? Thank you.
- de
Agregar un comentario
1 Respuesta
It is possible it could be a bad throttle body module. The code that you got basically means that the PCM is seeing low voltage (below .17) on the throttle position sensor circuit. Usually this is a pedal but it's possible to be the throttle position sensor or the actuator motor. Both of which are serviced in the throttle body. The throttle body is available on the aftermarket if you don't want to go factory.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Lonny Nohnychuk estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 25
Todo El Tiempo: 2,166
