Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
Preguntas 3820 Ver todo
had problem with no wifi and signal
@refectio is there any real way to tell if bb is bad or if its pm8019. this phone was liquid damaged before and dead. i got it working again but i worked around pm8019 and the audio ic. wifi was fine when i give it back to the person but got it back 2 days ago wifi was greyed out, so i looked at it today and turned out that c5202_rf was the cause. im not getting any signal, its either searching or no service. when i checked *#06# before removing c5202 it went off dial screen. now when i do it, its like it deletes the *#06# and stays on dial screen
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Respuesta
Respuesta Más Útil
You pretty much have to pull them to see what solves what, especially with water damaged boards.
Fue útil esta respuesta?
Calificación 2
Comentarios:
does it matter if some ground pads are missing from the bb ic
por
It might not matter. You should check the schematic to see if it is a true ground pin (usually connected together internally) or an input that requires it to be grounded (not connected internally).
por
Añadir tu respuesta
daniel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 39
