HP 260 G2 wont turn on after BIOS update
Hello,
I performed a BIOS update after installing Windows on a brand new device.
The installation seemed like it went well, but when it was done, it didn't work.
The screen stays blank, and the fans kick in very loudly after a bit.
I tried the Windows + B option they mention on HP's website but it doesn't work. Again this is a brand new device.
How can I fix it?
(PS I was not able to find this device in the list do I selected another one)
I tried to remove the BIOS battery and it didn't fix it.
And I just noticed, there is no power coming to the keyboard at all, so I can't even perform the Windows + B.
Es esta una buena pregunta?
Hi @enbrs ,
Try clearing and resetting the BIOS at least to see if you can start the PC and get into the BIOS menu screens
por jayeff
Do I need to apply electricity to the device and then press the button?
por BNN
Hi @enbrs ,
The note at Step 4 in the link says to remove the power before you press the button
por jayeff
Hey @jayeff,
I disconnected the power. Pressed and held the button for 5-6 seconds. Then closed the unit, and plugged everything in. Same thing, no power to keyboard, no output to monitor. Only the fan which start low and the goes high.
Is there anything else I can try?
por BNN
Hi @enbrs ,
Don't know if you tried this so if you have apologies.
Disconnect the HDD and see if it starts OK , enough to get into BIOS anyway. Just a thought.
por jayeff
I did. Nothing. Took it in, they will service it free of charge. Need to wait 2-3 weeks for a new board.
por BNN
Mostrar 1 comentario más
