Saltar al contenido principal
Guías de reparación y desmontaje de varios teléfonos móvil Samsung con Android, tanto nuevos como antiguos, incluyendo el modelo Samsung Galaxy. Todo lo que necesitas para reparar tu móvil Samsung.
Preguntas 13149 Ver todo
My phone won't turn on at all, stuck in downloading mode, dead battery
Well so yesterday I was using my phone as usual only difference was that battery was almost drained. Then, I accidentally accessed downloading mode and from there I couldn't do anything.. So I tried to charge it over night and turn it on again dozen times with different combinations but every time is gets to downloading os where it tells me to press vol up to continue and vol down to restart, after pressing down it gets into Samsung logo screen and turn itself off and now I can't turn it on at all. Doesn't react to charger. Sometimes it turns on, getting into download mode and turn back off.. I'm afraid I might loose all data is there any help?
EDIT: The problem is that my battery is dead and it refuses to charge because it is turned on on downloading mode..Sometimes when i press vol down, power button, home button it shows download os and if i hit vol down again ill get downloading mode on screen than it turn itself off.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
I have this same exact problem. Sorry but nothing anybody says, no combination will work. You might as well get a new phone because my phone no longer turns on nor is it responding to anything, so no button pressing will do anything.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
From download mode, have you tried simply holding the power down for 30 seconds? If so what happens?
Fue útil esta respuesta?
Puntuación 1
I think your battery is to empty, so it wont charge
If the battery removable try to charge directly using external charger. But if not removable, go to service center and ask them to change the battery
Puntuación 0
Añadir tu respuesta
Jakub estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 2,013
