Can we Replace iPhone 5s U2 Ic using Hair Dryer?
Hello guys i have iphone 5s and i want to replace u2 ic but i dont have latest equipment so i wana know can i user hair Dryer to Replace it?? Thanks
Es esta una buena pregunta?
@iamchhamza no you can not. Check on here Hair dryer for logic board reflow? to see why this will not work.
Fue útil esta respuesta?
No. A hair dryer only gets about 130 degrees F, well below the melting point of solder. Not to mention the fact that you can't control or focus the airflow; the heat will be baking the rest of the motherboard as you're working.
A hair dryer gets to only about 150F. For Ps3 solder fixes, I have seen people use a conventional oven because it does get hot enough. However, you have to know what you are doing, and be very quick and careful. There is a high risk of damaging the rest of the board or warping the board itself.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 195
