The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
Preguntas 3448 Ver todo
Dead after battery replacement
I replaced the battery in my Iphone 5S, but it won't power up. But - it seems to be charging because the phone is warm. The fact that it gets warm makes me thing the battery is plugged in OK. I carefully put it back together following the excellent guide. I did not tear the home button cable or other cables.
Any ideas would greatly be appreciated. I'm feeling pretty frustrated right now.
Thanks,
Brian
Update (12/31/2017)
I got the phone to come back to life by unconnecting the screen, battery, and home button, blowing out dust, and putting it back together.
The issue I have now is that the screen is flickering (looks like a slow refresh), and has some squares across the middle. It also has some vertical bars running from top to bottom. Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
2 Respuestas
Respuesta Más Útil
Chances are the replacment battery is faulty.
Can you try unplugging the battery and then plug the charger in to see if you get an apple logo, if you get an apple logo the issue is with the battery.
If you do not get an apple logo with then the issue is more likely to be either screen or U2 Tristar charging IC. Even with a bad charging IC you should be able to at least see an apple logo or it turning on properly with a charged battery.
Fue útil esta respuesta?
Calificación 1
Well there is probably something wrong with your phone. Even without an battery plugged into your phone and your phone plugged into power it should be able to atleast have the blacklights of the screen to turn on and go into a booting loop.
Calificación 0
Añadir tu respuesta
Brian Kowald estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 6
Últimos 30 Días: 30
Todo El Tiempo: 120
