Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3531 Ver todo
Home Button Not Working
Hello guys i am facing an issue with home button.My Iphone 5s home button not working after i replaced the panel . i saw many tutorials and replaced the panel and i also put the old home button in new panel but home button is not working. i tried many times but no result .so is it cable problem or phone problem ?
Help Will be appreciated thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
just try to reconnect the cable. It is very unlikely that it is the Motherboard unless you ripped the connector off the board. If that fails I would just replace the button. You will lose Touch ID though.
Fue útil esta respuesta?
Puntuación 0
4 comentarios:
is bracket is must while reconnecting the cable coz i lost the little bracket i am just connecting the cable
- de
The bracket that holds the home button in place? That is what puts pressure on the button. Put firm pressure on the back of the button while it is connected to the board and chances are it will work.
- de
No not that one i am talking about the connecting cable . when we connect the cable to board people put little bracket over the connector
- de
I have never seen a bracket that holds the home button connector in place. But like I said, just re-connecting. And no usually the bracket is just to make sure the connector doesnt pop off.
- de
Añadir tu respuesta
ch hamza estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 183
