The Canon EOS Rebel T3, also known as the 1100D, is a continuation of Canon's entry-level line of DSLR cameras, the Rebel series. It features an 18 MP sensor and a DIGIC 4 image processor.
Preguntas 36 Ver todo
Cannon Rebel T3 Err 01
My camera says that it has a faulty connection. Is this a general error, or is there a way I can fix the connection and use my camera again?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Philip Vecchio the Err 01 is a pretty generic error for a failure in communication between the camera and the lens. You could try and clean the contacts. If that does not work you could a. try your lens on a different body and see if the error shows as well. That would mean it is your lens that causes the error. If it does not, then you have an error with the body contacts. Stuck aperture blades on your lens can cause this as well.
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
Philip Vecchio estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 9
Últimos 30 Días: 39
Todo El Tiempo: 160
