Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
Preguntas 4105 Ver todo
iPhone is plugged in, shows low battery, but won't turn on.
I had it plugged in for about an hour on my regular charging cord. It worked fine on that cord early this morning at my friend's house. I switched the cord out with a newer one to see if that would fix it. I then plugged it into my laptop to see if maybe the outlet was the issue. I can't perform a hard reset because my home button does not work. The screen is responsive and displays the low battery icon when the wake/sleep button is pressed, but it won't turn even after charging for 30+ minutes.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Check for dirt in the charging port, its very usuall that there gets dirt in there so the phone dosent charge. (use a needle or something as small as that)
If that dosen't help I would test an other lightning connector connected to the motherboard to see if it chargs better.
Guide to replace lightning connector
Fue útil esta respuesta?
Calificación 0
Añadir tu respuesta
C Beuerlein estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 42
Últimos 30 Días: 186
Todo El Tiempo: 1,005
