Saltar al contenido principal
iPhone de 4 pulgadas lanzado en marzo de 2016 con especificaciones de hardware similares al 6s. Disponible en Plata, Gris espacial, Oro u Oro rosa con opciones de almacenamiento de 16/64 GB. Modelos A1662 y A1723.
Preguntas 1050 Ver todo
Blank Screen, Not Recognized by iTunes
I didn't drop it and it hasn't touched water. Just randomly died and I've charged it and I've tried to put it in DFU, Recovery and everything. Still not working, iTunes won't even recognize it.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
No dough that is the fault of Hardware and causes by U2 ic Because most of the iPhone have damage with such fault because of copy charger or an over charging then need.If you want further info on don`t forget to comment below.
U2 ic is that ic by which charging and power supply from battery will divided.If this ic makes function less then causes dead.
So you have to replace that ic only the solution.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Bella estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 142
