Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2189 Ver todo
Replaced display is dimming to dark
I replaced my display with an Ifixit replacement part and I did put in a new battery.
Everything worked fine (it is the 3rd time on this phone)
After a while I realized, that the display was showing some flickering which can barely be noticed.
I turned the brightness up and down to see if it would went away and then it got so dark that I couldn't turn it bright again.
After I finally got it back lighted I turned of the brightness adaption and rebooted several times.
When closing the phone everything seemed connected well.
There has been a screw - right above the Wifi-Cable connector which seemed loos and I tightened it.
Don't know what to check for.
The display goes dark, as soon as I turn down the brightness to 25-30%
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
It sounds like a defective screen, screen should not go extremely dark, contact iFixit about the issue and see if it qualifies for a warranty replacement.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Thanks I will contact them!
- de
Añadir tu respuesta
macdev estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 34
