The Stylo 2, the second iteration of the Stylo series, is manufactured by LG and was originally released in April 2016.
Preguntas 54 Ver todo
How can I remove unfortunately system ui has stopped working
How can I remove unfortunately system ui has stopped working but won't let me do anything else. Like log onto the phone
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Comentarios:
I found an app which solves this problem. You can download it from the play store. Here is the link: https://play.google.com/store/apps/detai...
Best Regards,
Eddi
por
Agregar un comentario
2 Respuestas
WARNING: Use caution when undertaking this process. One wrong selection can wipe your phone.
Ive had this same phone since it came out and needed to do this once. Still kickin
  • Power off your Android device
  • Hold the volume DOWN and power button until the recovery menu appears
  • Press volume down until the word Recovery is highlighted, then press the power button to reboot into recovery.
  • You should now see a black screen. Hold down the power button and press the volume UP until you see the recovery menu.
  • Using the DOWN key, navigate until you have wipe cache partition highlighted. Press the power button to erase the system cache. Once the cache is cleared, use the volume DOWN button to navigate to reboot to bootloader, and press the power button. Your device should reboot back to the original menu (see in first picture). Using the volume down button highlight REBOOT and press the power button. Your device should now reboot into Android with a cleaned system cache and a much improved OS.
Fue útil esta respuesta?
Calificación 0
What if Recovery is not an option? Only have the following: Continue Power Up, Safe mode, USB debug mode, Factory data reset, Wipe cache, and Power down. Which of these, if any, should I choose. Thanks!
Calificación 0
Añadir tu respuesta
Stephanie Figueroa estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 50
Últimos 7 Días: 366
Últimos 30 Días: 1,572
Todo El Tiempo: 4,606
