Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 1364 Ver todo
How to recover data from water damaged iPhone 7 Plus
My iphone 7 plus was dropped into water and now, it cannot work. But there is lots of important data in the phone. How to recover data from water damaged iPhone 7 plus? Please help. Thanks.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
The only way to recover data from an iPhone is to repair the phone "enough" to get it to boot and be recognized by iTunes. With water damaged devices, this is not always possible but certainly worth a try. A professional repair shop that does water damage repair may be able to recover your data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board.
If you want to try something yourself, then I suggest the following steps:
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, 80% of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
scottb.moore estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 2,010
