The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
Preguntas 3454 Ver todo
No screen,no sound,even not itunes cant detect my phone
Hey guys,i wanna ask you a question about my phone,today i wanted to replace my screen and battery (which i ordered and will be delivered next week),but just wanted to see first the phone inside,i read the guides here on the website and watches videos about it,i got out the screen successfully and the battery too,but after i placed the battery back and the screen without the metal brackets,just to see the phone is working,it doesn't give any sound or anything when i plug it to my pc,i know it's a dumb question as i am,but i dont know what to do now,i dont think i ripped any cable or connector cuz i was working with plastic tools and i was aware of having this problem..should i wait for the new screen+battery and try with those or did i did something wrong?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
can you post photos of around the connectors
por
check the charge port ribbon, make sure you didnt loosen it when disconnecting the battery also just goe over the connections again to make sure they are all connected properly
por
https://imgur.com/a/Fo0pI there are the pictures i took of the connectors
por
Maybe i damaged something on the main board?Can i even damage something on it while screwing and having my hand slipped and getting something damaged?
por
I didn't apply any pressure to the battery..i could try hard resetting,but my home button is not working,it didn't work since summer,i wanted to repair this too..
por
Mostrar 1 comentario más
Agregar un comentario
2 Respuestas
Respuesta Más Útil
How did you remove the battery; did the pull tabs work properly or did you have to pry the battery out?
There are some components near the edge of the logic board, just above the Dock connector, which can be damaged if you apply pressure to pry the battery. Most of those passives are related to the Audio Codec IC...
Fue útil esta respuesta?
Calificación 1
Try checking the ribbon cables near the dock connector. You might have damaged one of them. The next best bet is that you damaged the logic board. Good Luck Fixing.
Calificación 0
Añadir tu respuesta
B. Andrew estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 82
